No help with this???
Sorry about the wait, I only do this part time and Iāve been busy at work
Since the one odrive works and the other doesnāt, do an odrv0.erase_configuration() on the one that returns to 0.
No, shouldnāt. However the error codes wonāt necessarily match.
That doesnāt really make any sense for GIMBAL mode⦠are you very aggressively accelerating the drive maybe? Or what do you have set for motor.config.current_lim?
It kinda sounds to me like you might have a bunch of weird electrical noise issues.
- Are you using a USB isolator?
- Any ground loops?
- What does the wiring look like?
- Are you using the ferrite rings & shielded encoder cables?
Sorry for the delay, got struck down with covid.
Noise!!
If I turn off the LED office lights and sit in the dark it works
Iāve got a bag of ferrite rings on order to see if that helps, if not then new lights as these cheap ones are horrid!!
Sorry for the frustration, this thing has literally been driving me insane!!
I think a bit of covid induced time off helped clear the mind as wellā¦
