I’m using oDrive motor controller for an experimental setup in my research project. I’m using T-Motor P80 III Kv 120 motor with AMT212B-V absolute encoder.
I having a serious issue with this encoder. The wiring of the encoder looks fine, but the output for “odrv0.axis1.encoder.shadow_count” is always 0 though I turn the motor. I have set the encoder cpr to 16384 (14bit resolution) but I’m not getting any output.
However, I checked the encoder, using AMT viewpoint software, it works perfectly.
Could anyone please help me in getting this encoder works with oDrive motor controller.
yes, i had assumed this was one of the SPI encoders.
The RS485 will not work. Maybe you can use the AB incremental interface only, but it will not be very useful on its own. you’ll need a full calibration on each boot up
