Anti-cogging issues on the latest firmware
I have been having a terrible time getting anticogging to work using all the same settings as I have previously used without issue since the firmware upgrade.
When I run the anticogging routine it goes very slowly and never seems to finish - I have a bit of vibration and some movement initially but then nothing.
I have upped the pos / vel integrator gains e.g.
   odrv0.axis1.controller.config.pos_gain = 15 * 10
   odrv0.axis1.controller.config.vel_integrator_gain  = (0.5 * 10 * 0.32/2 )*10
I’ve also tried increasing the motor calibration and voltage e.g:
    odrv0.axis0.motor.config.calibration_current=20
    odrv0.axis1.motor.config.resistance_calib_max_voltage = 6
I’ve also removed all possible loads from the motor. I’m using the Odrive Robotics D5065 270KV motors with the 3.6 so pretty vanilla setup.
I feel like I’m losing my mind - I created a youtube video on antocogging a couple of years ago so I feel like I had this down pretty well but it’s not working for me. Any thoughts from the hivemind would be greatly appreciated.
Hi Andy,
What was the previous firmware you were upgrading from? The pos/vel gain units changed in 0.5.1, so that may be the source of the issues.
You sure your torque_limit and current_limit is high enough? also your vel_limit, as it might interfere if it’s vibrating
It’s absolutely possible that it’s too low if the units have changed. Do you have a suggestion of appropriate values to try with this motor by chance?
Is this a bare D5065? No output load or anything? What encoder?
Its a bare D5065 motor, AMT102-V capacitive encoder. All from the odrive robotics store so its pretty standard
if it helps, the exact code I’m using to set the motor up is here: Implementing Anti-Cogging on the ODrive Robotics Controller - andyvickers.net
It gets weirder … if I set odrv0.axis0.controller.config.vel_integrator_gain = 4 and rest my hand very lightly on the motor, it stops vibrating and starts doing the anti-cogging routine. I have no earthly idea why that would be.
