Axis1 works improperly
Hello everyone,
I’m using:
FL80BLS120 motor (48V, 1400RPM, 8 poles, sensored),
FL80BLS120 motor (48V, 2040RPM, 8 poles, sensored),
Odrive V3.6 (56 Voltage version).
I configured both axis# the same way.
For some reason axis0 works as expected while axis1 doesn’t.
I tried switching motors with axis#, tried to switch Drive, and tried to change parameters.
It seems like the problem is not the motor, but the configuration, but I can’t find the problem.
I opened the GUI to see what really happens and here is what I found:
  1. When Homing it spins much faster than it is configured to and takes a long time to go to offset after clicking the limit switch (end stop switch).
  2. After homing I see its start position/offset is -300 although it is set to -10.
  3. When I tell it to spin 1 turn it spins infinitely until I press the end stop switch or change its state to IDLE
  4. When I print position to the terminal after setting position it shows what I set it to and not what it shows on the GUI and really doing.
here is the JSON:
    "axis0":{
       "config":{
          "can_heartbeat_rate_ms":100,
          "can_node_id_extended":false,
          "can_node_id":0,
          "dir_gpio_pin":2,
          "enable_step_dir":false,
          "enable_watchdog":false,
          "startup_closed_loop_control":false,
          "startup_encoder_index_search":false,
          "startup_encoder_offset_calibration":false,
          "startup_homing":true,
          "startup_motor_calibration":false,
          "startup_sensorless_control":false,
          "step_dir_always_on":false,
          "step_gpio_pin":1,
          "turns_per_step":0.0009765625,
          "watchdog_timeout":0.0,
          "calibration_lockin":{
             "accel":20.0,
             "current":10.0,
             "ramp_distance":3.1415927410125732,
             "ramp_time":0.4000000059604645,
             "vel":40.0
          "general_lockin":{
             "accel":200.0,
             "current":20.0,
             "finish_distance":100.0,
             "finish_on_distance":false,
             "finish_on_enc_idx":false,
             "finish_on_vel":false,
             "vel":40.0
          "sensorless_ramp":{
             "accel":200.0,
             "current":10.0,
             "finish_on_vel":true,
             "vel":400.0
       "controller":{
          "config":{
             "axis_to_mirror":255,
             "circular_setpoint_range":1.0,
             "circular_setpoints":false,
             "control_mode":3,
             "enable_current_mode_vel_limit":true,
             "enable_gain_scheduling":false,
             "enable_overspeed_error":true,
             "enable_vel_limit":true,
             "gain_scheduling_width":10.0,
             "homing_speed":10.0,
             "inertia":0.0,
             "input_filter_bandwidth":2.0,
             "input_mode":1,
             "load_encoder_axis":0,
             "mirror_ratio":1.0,
             "pos_gain":1.0,
             "torque_ramp_rate":0.009999999776482582,
             "vel_gain":0.24810001254081726,
             "vel_integrator_gain":1.2405000925064087,
             "vel_limit":2000.0,
             "vel_limit_tolerance":1.2000000476837158,
             "vel_ramp_rate":1.0,
             "anticogging":{
                "anticogging_enabled":true,
                "calib_anticogging":false,
                "calib_pos_threshold":1.0,
                "calib_vel_threshold":1.0,
                "cogging_ratio":1.0,
                "index":0,
                "pre_calibrated":false
       "encoder":{
          "config":{
             "abs_spi_cs_gpio_pin":1,
             "bandwidth":100.0,
             "calib_range":0.019999999552965164,
             "calib_scan_distance":150.0,
             "calib_scan_omega":12.566370964050293,
             "cpr":24,
             "enable_phase_interpolation":true,
             "find_idx_on_lockin_only":false,
             "idx_search_unidirectional":false,
             "ignore_illegal_hall_state":false,
             "mode":1,
             "offset_float":0.3299543261528015,
             "offset":-66,
             "pre_calibrated":false,
             "sincos_gpio_pin_cos":4,
             "sincos_gpio_pin_sin":3,
             "use_index":false,
             "zero_count_on_find_idx":true
       "fet_thermistor":{
          "config":{
             "enabled":true,
             "temp_limit_lower":100.0,
             "temp_limit_upper":120.0
       "max_endstop":{
          "config":{
             "debounce_ms":50,
             "enabled":true,
             "gpio_num":7,
             "is_active_high":false,
             "offset":-10.0,
             "pullup":true
       "min_endstop":{
          "config":{
             "debounce_ms":50,
             "enabled":true,
             "gpio_num":8,
             "offset":-10.0,
             "pullup":true
       "motor":{
          "config":{
             "acim_autoflux_attack_gain":10.0,
             "acim_autoflux_decay_gain":1.0,
             "acim_autoflux_enable":false,
             "acim_autoflux_min_Id":10.0,
             "acim_gain_min_flux":10.0,
             "acim_slip_velocity":14.706000328063965,
             "calibration_current":10.0,
             "current_control_bandwidth":100.0,
             "current_lim_margin":8.0,
             "current_lim":10.0,
             "direction":-1,
             "inverter_temp_limit_lower":100.0,
             "inverter_temp_limit_upper":120.0,
             "motor_type":0,
             "phase_inductance":0.0004909285344183445,
             "phase_resistance":0.10748489946126938,
             "pole_pairs":4,
             "pre_calibrated":true,
             "requested_current_range":25.0,
             "resistance_calib_max_voltage":4.0,
             "torque_constant":0.5168750286102295,
             "torque_lim":"Infinity"
       "motor_thermistor":{
          "config":{
             "enabled":false,
             "gpio_pin":4,
             "poly_coefficient_0":0.0,
             "poly_coefficient_1":0.0,
             "poly_coefficient_2":0.0,
             "poly_coefficient_3":0.0,
       "sensorless_estimator":{
          "config":{
             "observer_gain":1000.0,
             "pll_bandwidth":1000.0,
             "pm_flux_linkage":0.0015800000401213765
       "trap_traj":{
          "config":{
             "accel_limit":0.5,
             "decel_limit":0.5,
             "vel_limit":1000.0
    "axis1":{
       "config":{
          "can_node_id":1,
          "dir_gpio_pin":4,
          "step_gpio_pin":3,
             "accel":20.0,
             "current":10.0,
             "vel":40.0
          "general_lockin":{
             "accel":200.0,
             "current":20.0,
             "vel":40.0
          "sensorless_ramp":{
             "accel":200.0,
             "current":10.0,
             "vel":400.0
       "controller":{
          "config":{
             "control_mode":3,
             "inertia":0.0,
             "input_mode":1,
             "mirror_ratio":1.0,
             "pos_gain":1.0,
             "vel_limit":2000.0,
             "anticogging":{
                "index":0,
       "encoder":{
          "config":{
             "bandwidth":100.0,
             "cpr":24,
             "mode":1,
             "offset_float":0.32997530698776245,
             "offset":-72,
             "use_index":false,
       "fet_thermistor":{
          "config":{
             "enabled":true,
       "max_endstop":{
          "config":{
             "debounce_ms":50,
             "enabled":true,
             "gpio_num":5,
             "offset":-10.0,
             "pullup":true
       "min_endstop":{
          "config":{
             "debounce_ms":50,
             "enabled":true,
             "gpio_num":6,
             "offset":-10.0,
             "pullup":true
       "motor":{
          "config":{
             "current_lim":10.0,
             "direction":-1,
             "motor_type":0,
             "phase_inductance":0.0004563182301353663,
             "phase_resistance":0.1059090718626976,
             "pole_pairs":4,
          "config":{
             "enabled":false,
             "gpio_pin":4,
          "config":{
       "trap_traj":{
          "config":{
             "accel_limit":0.5,
             "decel_limit":0.5,
             "vel_limit":1000.0
    "can":{
       "config":{
          "baud_rate":250000,
          "protocol":0
    "config":{
       "brake_resistance":2.0,
       "dc_bus_overvoltage_ramp_end":59.92000198364258,
       "dc_bus_overvoltage_ramp_start":59.92000198364258,
       "dc_bus_overvoltage_trip_level":59.92000198364258,
       "dc_bus_undervoltage_trip_level":8.0,
       "dc_max_negative_current":-9.999999974752427e-07,
       "dc_max_positive_current":"Infinity",
       "enable_ascii_protocol_on_usb":true,
       "enable_dc_bus_overvoltage_ramp":false,
       "enable_i2c_instead_of_can":false,
       "enable_uart":true,
       "max_regen_current":0.0,
       "uart_baudrate":115200,
       "gpio1_pwm_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
       "gpio2_pwm_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
       "gpio3_analog_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
       "gpio3_pwm_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
       "gpio4_analog_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
       "gpio4_pwm_mapping":{
          "endpoint":null,
          "max":0.0,
          "min":0.0
Thanks for the helpers in advance :slight_smile:
