Backup- and restore-config cycle error
Hi, all!
When I do a backup- and restore-config with the odrivetool (first ‘odrivetool backup-config’, then ‘odrivetool restore-config’), where I restore the backup file I just created, the setting encoder.config.pre_calibrated is now false, but was true before created the backup. What is wrong here (this setting seems to be lost in backup-restore cycle)?
This Json doesn’t work:
{"config": {"enable_uart": true, "uart_baudrate": 115200, "enable_i2c_instead_of_can": false, "enable_ascii_protocol_on_usb": true, "max_regen_current": 0.0, "brake_resistance": 3.0, "dc_bus_undervoltage_trip_level": 8.0, "dc_bus_overvoltage_trip_level": 59.92000198364258, "enable_dc_bus_overvoltage_ramp": false, "dc_bus_overvoltage_ramp_start": 59.92000198364258, "dc_bus_overvoltage_ramp_end": 59.92000198364258, "dc_max_positive_current": Infinity, "dc_max_negative_current": -9.999999974752427e-07}, "axis0": {"config": {"startup_motor_calibration": false, "startup_encoder_index_search": false, "startup_encoder_offset_calibration": false, "startup_closed_loop_control": false, "startup_sensorless_control": false, "startup_homing": false, "enable_step_dir": false, "step_dir_always_on": false, "turns_per_step": 0.0009765625, "watchdog_timeout": 0.0, "enable_watchdog": false, "step_gpio_pin": 1, "dir_gpio_pin": 2, "can_node_id": 0, "can_node_id_extended": false, "can_heartbeat_rate_ms": 100}, "fet_thermistor": {"config": {"temp_limit_lower": 100.0, "temp_limit_upper": 120.0, "enabled": true}}, "motor_thermistor": {"config": {"gpio_pin": 4, "poly_coefficient_0": 0.0, "poly_coefficient_1": 0.0, "poly_coefficient_2": 0.0, "poly_coefficient_3": 0.0, "temp_limit_lower": 100.0, "temp_limit_upper": 120.0, "enabled": false}}, "motor": {"config": {"pre_calibrated": true, "pole_pairs": 11, "calibration_current": 10.0, "resistance_calib_max_voltage": 2.0, "phase_inductance": 9.170889825327322e-05, "phase_resistance": 0.16107943654060364, "torque_constant": 0.05168750137090683, "direction": 1, "motor_type": 0, "current_lim": 10.0, "current_lim_margin": 8.0, "torque_lim": Infinity, "inverter_temp_limit_lower": 100.0, "inverter_temp_limit_upper": 120.0, "requested_current_range": 60.0, "current_control_bandwidth": 1000.0, "acim_slip_velocity": 14.706000328063965, "acim_gain_min_flux": 10.0, "acim_autoflux_min_Id": 10.0, "acim_autoflux_enable": false, "acim_autoflux_attack_gain": 10.0, "acim_autoflux_decay_gain": 1.0}}, "controller": {"config": {"gain_scheduling_width": 10.0, "enable_vel_limit": true, "enable_current_mode_vel_limit": true, "enable_gain_scheduling": false, "enable_overspeed_error": true, "control_mode": 1, "input_mode": 1, "pos_gain": 20.0, "vel_gain": 0.1666666716337204, "vel_integrator_gain": 0.3333333432674408, "vel_limit": 20.0, "vel_limit_tolerance": 1.2000000476837158, "vel_ramp_rate": 0.4000000059604645, "torque_ramp_rate": 0.009999999776482582, "circular_setpoints": false, "circular_setpoint_range": 1.0, "homing_speed": 0.25, "inertia": 0.0, "axis_to_mirror": 255, "mirror_ratio": 1.0, "load_encoder_axis": 0, "input_filter_bandwidth": 2.0}}, "encoder": {"config": {"mode": 0, "use_index": true, "find_idx_on_lockin_only": false, "abs_spi_cs_gpio_pin": 1, "zero_count_on_find_idx": true, "cpr": 4096, "offset": 1588, "pre_calibrated": true, "offset_float": 1.4825313091278076, "enable_phase_interpolation": true, "bandwidth": 1000.0, "calib_range": 0.019999999552965164, "calib_scan_distance": 50.26548385620117, "calib_scan_omega": 12.566370964050293, "idx_search_unidirectional": false, "ignore_illegal_hall_state": false, "sincos_gpio_pin_sin": 3, "sincos_gpio_pin_cos": 4}}, "sensorless_estimator": {"config": {"observer_gain": 1000.0, "pll_bandwidth": 1000.0, "pm_flux_linkage": 0.0015800000401213765}}, "trap_traj": {"config": {"vel_limit": 2.0, "accel_limit": 0.5, "decel_limit": 0.5}}, "min_endstop": {"config": {"gpio_num": 0, "enabled": false, "offset": 0.0, "is_active_high": false, "pullup": true, "debounce_ms": 50}}, "max_endstop": {"config": {"gpio_num": 0, "enabled": false, "offset": 0.0, "is_active_high": false, "pullup": true, "debounce_ms": 50}}}, "axis1": {"config": {"startup_motor_calibration": false, "startup_encoder_index_search": false, "startup_encoder_offset_calibration": false, "startup_closed_loop_control": false, "startup_sensorless_control": false, "startup_homing": false, "enable_step_dir": false, "step_dir_always_on": false, "turns_per_step": 0.0009765625, "watchdog_timeout": 0.0, "enable_watchdog": false, "step_gpio_pin": 7, "dir_gpio_pin": 8, "can_node_id": 1, "can_node_id_extended": false, "can_heartbeat_rate_ms": 100}, "fet_thermistor": {"config": {"temp_limit_lower": 100.0, "temp_limit_upper": 120.0, "enabled": true}}, "motor_thermistor": {"config": {"gpio_pin": 4, "poly_coefficient_0": 0.0, "poly_coefficient_1": 0.0, "poly_coefficient_2": 0.0, "poly_coefficient_3": 0.0, "temp_limit_lower": 100.0, "temp_limit_upper": 120.0, "enabled": false}}, "motor": {"config": {"pre_calibrated": true, "pole_pairs": 11, "calibration_current": 10.0, "resistance_calib_max_voltage": 2.0, "phase_inductance": 8.54182944749482e-05, "phase_resistance": 0.16203509271144867, "torque_constant": 0.05168750137090683, "direction": 1, "motor_type": 0, "current_lim": 10.0, "current_lim_margin": 8.0, "torque_lim": Infinity, "inverter_temp_limit_lower": 100.0, "inverter_temp_limit_upper": 120.0, "requested_current_range": 60.0, "current_control_bandwidth": 1000.0, "acim_slip_velocity": 14.706000328063965, "acim_gain_min_flux": 10.0, "acim_autoflux_min_Id": 10.0, "acim_autoflux_enable": false, "acim_autoflux_attack_gain": 10.0, "acim_autoflux_decay_gain": 1.0}}, "controller": {"config": {"gain_scheduling_width": 10.0, "enable_vel_limit": true, "enable_current_mode_vel_limit": true, "enable_gain_scheduling": false, "enable_overspeed_error": true, "control_mode": 1, "input_mode": 1, "pos_gain": 20.0, "vel_gain": 0.1666666716337204, "vel_integrator_gain": 0.3333333432674408, "vel_limit": 20.0, "vel_limit_tolerance": 1.2000000476837158, "vel_ramp_rate": 0.4000000059604645, "torque_ramp_rate": 0.009999999776482582, "circular_setpoints": false, "circular_setpoint_range": 1.0, "homing_speed": 0.25, "inertia": 0.0, "axis_to_mirror": 255, "mirror_ratio": 1.0, "load_encoder_axis": 1, "input_filter_bandwidth": 2.0}}, "encoder": {"config": {"mode": 0, "use_index": true, "find_idx_on_lockin_only": false, "abs_spi_cs_gpio_pin": 1, "zero_count_on_find_idx": true, "cpr": 4096, "offset": 2583, "pre_calibrated": true, "offset_float": 0.5364999771118164, "enable_phase_interpolation": true, "bandwidth": 1000.0, "calib_range": 0.019999999552965164, "calib_scan_distance": 50.26548385620117, "calib_scan_omega": 12.566370964050293, "idx_search_unidirectional": false, "ignore_illegal_hall_state": false, "sincos_gpio_pin_sin": 3, "sincos_gpio_pin_cos": 4}}, "sensorless_estimator": {"config": {"observer_gain": 1000.0, "pll_bandwidth": 1000.0, "pm_flux_linkage": 0.0015800000401213765}}, "trap_traj": {"config": {"vel_limit": 2.0, "accel_limit": 0.5, "decel_limit": 0.5}}, "min_endstop": {"config": {"gpio_num": 0, "enabled": false, "offset": 0.0, "is_active_high": false, "pullup": true, "debounce_ms": 50}}, "max_endstop": {"config": {"gpio_num": 0, "enabled": false, "offset": 0.0, "is_active_high": false, "pullup": true, "debounce_ms": 50}}}, "can": {"config": {"baud_rate": 250000, "protocol": 0}}}
That one doesn’t work either:
    "axis0": {
        "config": {
            "can_heartbeat_rate_ms": 100,
            "can_node_id": 0,
            "dir_gpio_pin": 2,
            "step_gpio_pin": 1,
        "controller": {
            "config": {
                "control_mode": 1,
                "inertia": 0.0,
                "input_filter_bandwidth": 2.0,
                "input_mode": 6,
                "pos_gain": 20.0,
                "vel_limit": 20.0,
        "encoder": {
            "config": {
                "cpr": 4096,
                "mode": 0,
                "offset": 1586,
                "offset_float": 0.7461405992507935,
                "sincos_gpio_pin_cos": 4,
                "use_index": true,
        "fet_thermistor": {
            "config": {
                "enabled": true,
        "max_endstop": {
            "config": {
                "debounce_ms": 50,
                "enabled": false,
                "gpio_num": 0,
                "offset": 0.0,
                "pullup": true
        "min_endstop": {
            "config": {
                "debounce_ms": 50,
                "enabled": false,
                "gpio_num": 0,
                "offset": 0.0,
                "pullup": true
        "motor": {
            "config": {
                "acim_autoflux_decay_gain": 1.0,
                "direction": 1,
                "motor_type": 0,
                "phase_inductance": 9.212127042701468e-05,
                "phase_resistance": 0.15011364221572876,
                "pole_pairs": 11,
                "torque_constant": 0.03999999910593033,
            "config": {
                "enabled": false,
                "gpio_pin": 4,
            "config": {
        "trap_traj": {
            "config": {
                "accel_limit": 0.5,
                "decel_limit": 0.5,
                "vel_limit": 2.0
    "axis1": {
        "config": {
            "can_node_id": 1,
            "dir_gpio_pin": 8,
            "step_gpio_pin": 7,
        "controller": {
            "config": {
                "control_mode": 2,
                "inertia": 0.0,
                "input_mode": 2,
                "pos_gain": 20.0,
                "vel_limit": 20.0,
        "encoder": {
            "config": {
                "cpr": 4096,
                "mode": 0,
                "offset": 2583,
                "offset_float": 0.7067656517028809,
                "use_index": true,
        "fet_thermistor": {
            "config": {
                "enabled": true,
        "max_endstop": {
            "config": {
                "debounce_ms": 50,
                "enabled": false,
                "gpio_num": 0,
                "offset": 0.0,
                "pullup": true
        "min_endstop": {
            "config": {
                "debounce_ms": 50,
                "enabled": false,
                "gpio_num": 0,
                "offset": 0.0,
                "pullup": true
        "motor": {
            "config": {
                "direction": 1,
                "motor_type": 0,
                "phase_inductance": 8.462630648864433e-05,
                "phase_resistance": 0.1519850790500641,
                "pole_pairs": 11,
            "config": {
                "enabled": false,
                "gpio_pin": 4,
            "config": {
        "trap_traj": {
            "config": {
                "accel_limit": 0.5,
                "decel_limit": 0.5,
                "vel_limit": 2.0
    "can": {
        "config": {
            "protocol": 0
    "config": {
        "dc_max_negative_current": -9.999999974752427e-07,
Can you upload your JSON config?
I’m going to guess it’s just this problem:
void Encoder::check_pre_calibrated() {
    // TODO: restoring config from python backup is fragile here (ACIM motor type must be set first)
    if (!is_ready_ && axis_->motor_.config_.motor_type != Motor::MOTOR_TYPE_ACIM)
        config_.pre_calibrated = false;
    if (mode_ == MODE_INCREMENTAL && !index_found_)
From Discord:
Paul Wetmelon Today at 6:45 PM
I posted a bug for you here https://github.com/madcowswe/ODrive/issues/541
jiuy Today at 6:47 PM
  1. How long do you think until it’s fixed?
  2. Can workaround this issue somehow?
  3. E.g. What if I set motor type to MOTOR_TYPE_ACIM before doing and restoring the backup, and then after set motor type to MOTOR_TYPE_HIGH_CURRENT again?
Restoring a backup with encoder.pre_calibrated = True works, if I do a AXIS_STATE_ENCODER_INDEX_SEARCH on both axis before! – And after the backup, encoder pre_calibrated = True!
DID NOT WORK: I set motor type to MOTOR_TYPE_ACIM before doing and restoring the backup, and then after set motor type to MOTOR_TYPE_HIGH_CURRENT. – After this, encoder pre_calibrated = false.
Any updates on this issue? I’ve seen that you closed the issue, but I still have the same problem
E: My current workaround is starting the odrive, doing an index search and then restoring the configuration. This way the index will be found right on startup and the encoder is still pre calibrated.
Hey Lars, we don’t consider this a bug tbh. We can’t trust that a restored config is valid for encoder alignment. The risk of spinout / damage is too high compared to the inconvenience of having to use a workaround to get a restored config to be valid immediately.
