Hello there
I currently am developing a robot arm using Odrives, with some transmissions in place to increase end effector torque. This means Ratios somewhere between 60:1 and 100:1 of motor rotation to end effector rotation.
I’ll need to add some endstops, so ROS2 control knows where the arm is in space.
Is it possible to hook the ODrive up to a couple of hall effect sensors, and have the data pass through that they are active or not via canbus, so I can tell ROS2 the position of the endstop.
I’d clearly prefer to use absolute value encoders, but those wont work in the case of using cycloidal gears.
It seems that I’d need to edit the ROS2 Hardware Interface a little bit in order to pass through this data. Does anyone have good insight of a simple change that would need to be made?
I currently have 6 Odrives up and running, each controlling an M8325 motor via CAN, connected to ROS2. They are able to give feedback that shows position in RVIZ (which models robot arm positions).
Thanks for looking
-Chris
