I already write the tup.config.default’s CONFIG_BOARD_VERSION=v3.5-24V, then make, but still report:
tup error [string “Tupfile.lua”]:43: board version not specified - take a look at tup.config.default
stack traceback:
[C]: in function ‘error’
[string “Tupfile.lua”]:43: in main chunk
[ ETA~=<1s Remaining=51 ] 1%
*** tup: 1 job failed.
Makefile:14: recipe for target ‘all’ failed
make: *** [all] Error 1
I’ve added the board version: CONFIG_BOARD_VERSION=v3.6-56V to the tup.config.default.
Here are the contents of the file:
# Copy this file to tup.config and adapt it to your needs
# make sure this fits your board
CONFIG_USB_PROTOCOL=native
CONFIG_UART_PROTOCOL=ascii
CONFIG_DEBUG=false
# Uncomment this to error on compilation warnings
CONFIG_STRICT=true
I also made a copy of the file and renamed it to tup.config. However, I still run into the issue.
Any help would be appreciated as I am running a on time crunch project.
A file named tup.config in the Firmware directory with the following settings works for me:
CONFIG_DEBUG=false
#CONFIG_STRICT=true
