What is the main reason a brake resistance unit gets very hot to the point It can’t be touch.?
I did configure the odrive using few instructions.After running the tool odrive_demo.py, the motor seems to be working fine however, the brake resistance unit get extremely hot.
I haven’t set anything related to tuning and/or position control. Can please,anybody give me a hand?
Thanks in advance
The initial config instructions given were as follows:
odrv0.axis0.encoder.config.use_index =True
odrv0.axis0.encoder.config.pre_calibrated=True
odrv0.axis0.motor.config.pole_pairs=7
odrv0.axis0.motor.config.motor_type=MOTOR_TYPE_HIGH_CURRENT
odrv0.config.brake_resistance=0.47
odrv0.axis0.encoder.config.cpr=8192
odrv0.axis0.encoder.config,use_index
My inventory
- Odrive 3.4
- Encoder AMT102V
- Power supply 24V 13A
- Turnigy 4250 410
fatal: not a git repository (or any of the parent directories): .git
ro exit status 128.
ODrive control utility v0.0.0.dev
Developer Preview
If you find issues, please report them
on https://github.com/madcowswe/ODrive/issues
or better yet, submit a pull request to fix it.
Please connect your ODrive.
Connected to ODrive 306439923235 as odrv0
error = 0x0000 (int)
current_state = 8 (int)
requested_state = 0 (int)
loop_counter = 9201822 (int)
config:
counts_per_step = 2.0 (float)
ramp_up_time = 0.4000000059604645 (float)
ramp_up_distance = 12.566370964050293 (float)
spin_up_current = 10.0 (float)
spin_up_acceleration = 400.0 (float)
spin_up_target_vel = 400.0 (float)
motor:
armed_state = 3 (int)
is_calibrated = True (bool)
current_meas_phB = -0.015164673328399658 (float)
current_meas_phC = 0.23015892505645752 (float)
DC_calib_phB = -0.7500070929527283 (float)
DC_calib_phC = -2.083026647567749 (float)
phase_current_rev_gain = 0.02500000037252903 (float)
current_control: ...
gate_driver: ...
timing_log: ...
config: ...
controller:
pos_setpoint = 500000.0 (float)
vel_setpoint = 0.0 (float)
vel_integrator_current = -0.0854005292057991 (float)
config: ...
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_fo
rward: float)
encoder:
is_ready = True (bool)
index_found = True (bool)
shadow_count = 500000 (int)
count_in_cpr = 7335 (int)
offset = -4103 (int)
interpolation = 0.5 (float)
phase = -1.418288230895996 (float)
pos_estimate = 500000.9375 (float)
pos_cpr = 7335.7685546875 (float)
hall_state = 2 (int)
pll_vel = 0.0 (float)
pll_kp = 2000.0 (float)
pll_ki = 1000000.0 (float)
config: ...
sensorless_estimator:
phase = 2.796194553375244 (float)
pll_pos = 2.7967867851257324 (float)
pll_vel = -0.25987279415130615 (float)
In [5]:
