I am facing an issue which seems to have no possible resolution with the any of the setting options. There seems to be an error "BRAKE_CURRENT_OUT_OF_RANGE ", but the user doesnot have any direct control over this limit. I know that we can fiddle around with brake resistance , current limit and requested_current_range, trying to find the perfect combination which will work. But isnt this stupid? There is no direct control over brake current limit but there exists an error which proclaims the same.
Also, if I try to decrease the brake resistance I will encounter “DC BUS OVER VOLTAGE” since the power is being put back to vbus. Why cant there be an option where the user can determine the power rating/maximum current limitations of the attached resistor?
