Hi
I can see a lot of dedicated procedures for communicating wia CAN from C++.
However I am not able to decode how I can send commands lige
set_linear_count = 0
or
reboot()
from C++
Whar are the syntx for doing so?
Hi
or
reboot()
from C++
Hi! Is this on e.g. an Arduino, or from Linux or Windows or something like that?
Hi
Running on a Teensy 4.1.
Using FlexCAN_T4-master and the ODrive library.
Just checking, is this an ODrive S1/Pro/Micro, or a v3.6?
Hi
S1
Gotcha!
The reason I ask - set_linear_count is an old command from the v3.6 days, it’s no longer used. The equivalent would be to write to pos_estimate, which has a CAN message - Set_Absolute_Position. In Arduino, you would write e.g. odrive.setAbsolutePosition(0). For reboots, you would write odrive.reset(), or you can e.g. save configuration with odrive.reset(ODriveCAN::ResetAction::SaveConfiguration). You can see more information on the library reference here: Controlling ODrive from an Arduino via CAN — ODrive Documentation 0.6.11 documentation
HI
Thanks.
However I am not able to get it compiled.
Not even odrv0.reset();
What is the syntax for
please fill out
odrv0.reset(???);
BTW is there any examples with some of these special calls that does not have CAN messages?
I have to set the GPIO’s as weel and guess I need to use odrv0.setEndpoint(???);
