I am using odrive 3.6 with firmware 5.1. I am using this code for communication https://github.com/johnkok/ros_odrive. While using the older firmware it was working fine , after upgrading to 5.1 there are issue with reading (getting timeout error using usb). How can i solve this ?
Is there any c++ code that works with version 5.1 for reference
You might want to check if your CRC is up to date. As it changes with firmware versions. I’ve had the same issue: Native protocol issues
It worked , thanks a lot
can u tell me how to use it as i am having issue that some file are not being included.
