Hi all,
I am new to odrive. My odrive (v3.5) (0.4.11) does not have the commands for the CAN.
I am trying to connect 2 odrives together for a robot and i am completely lost on how to implement that.
When i try to set the baudrate (odrv0.can.set_baud_rate(value)) it says “object has no attribute set_baud_rate”.
Even when trying to set nodes (odrv0.axis0.can_node_id = 0x010) or (odrv0.axis0.config.can_node_id = 3) for example, it saya “Attribute can_node_id not found”
Do any of you fellas have a nice and basic documentation of getting 2 odrives connected and communicating over can bus?
P.S. i did update the firmware and this did not help
Thanks in advance.
