It’s been a while now that can protocol commands don’t work.
It puts out an error saying "object has no attribute ‘can’ " when I run the following command
odrv0.axis0.config.can.node_id=0
(That problem doesn’t apply when I put the can command like here: odrv0.can.config.baud_rate
In the beginning I thought it was a firmware problem since at the time I hadn’t upgraded to the final one, but everything is perfectly upgraded and I still get that error.
Are you sure you have updated the firmware? Maybe you updated the odrive pip package (i.e. odrivetool) but the odrive still runs the old firmware?
What does the odrive itself report its version as?
