I’ve been using the ODrive 3.5 (v0.4.7) in position control mode with the function odrv0.axis0.controller.pos_setpoint and it works great but I can’t seem to get Trajectory control to work following the ODrive documentation. I’m using the D6374 150KV and 8192 CPM encoder from the odrive shop.
When I try to look at/set the parameters for trajectory control through odrivetool I get this:
In [23]: odrv0.axis0.trap_traj.config.vel_limit
~\Anaconda3\lib\site-packages\fibre\shell.py in
----> 1 odrv0.axis0.trap_traj.config.vel_limit
~\Anaconda3\lib\site-packages\fibre\remote_object.py in getattribute(self, name)
243 return attr
244 else:
–> 245 return object.getattribute(self, name)
246 #raise AttributeError(“Attribute {} not found”.format(name))
247
AttributeError: ‘RemoteObject’ object has no attribute ‘trap_traj’
and when I try to use the move_to_pos function I get this:
In [18]: odrv0.axis0.controller.move_to_pos(50)
----> 1 odrv0.axis0.controller.move_to_pos(50)
243 return attr
244 else:
247
AttributeError: ‘RemoteObject’ object has no attribute ‘move_to_pos’
Is there something I’m missing? Suggested path forward? Thanks so much!
