My oDrive can’t start a thread when I turn on Power.
it can update the requested_state status
`* odrv0
- Out[98]:
- vbus_voltage = 12.0 (float)
- ibus = 0.0 (float)
- serial_number = 2086359B524B (int)
- hw_version_major = 3 (int)
- hw_version_minor = 6 (int)
- hw_version_variant = 24 (int)
- fw_version_major = 0 (int)
- fw_version_minor = 5 (int)
- fw_version_revision = 0 (int)
- fw_version_unreleased = 1 (int)
- user_config_loaded = True (bool)
- brake_resistor_armed = False (bool)
- brake_resistor_saturated = False (bool)
- system_stats:
- uptime = 0 (int)
- min_heap_space = 0 (int)
- min_stack_space_axis0 = 0 (int)
- min_stack_space_axis1 = 0 (int)
- min_stack_space_comms = 0 (int)
- min_stack_space_usb = 0 (int)
- min_stack_space_uart = 0 (int)
- min_stack_space_can = 0 (int)
- min_stack_space_usb_irq = 0 (int)
- min_stack_space_startup = 0 (int)
- stack_usage_axis0 = 0 (int)
- stack_usage_axis1 = 0 (int)
- stack_usage_comms = 0 (int)
- stack_usage_usb = 0 (int)
- stack_usage_uart = 0 (int)
- stack_usage_usb_irq = 0 (int)
- stack_usage_startup = 0 (int)
- stack_usage_can = 0 (int)
- usb: …
- i2c: …
- config:
- brake_resistance = 0.4699999988079071 (float)
- max_regen_current = 0.0 (float)
- enable_uart = True (bool)
- uart_baudrate = 115200 (int)
- enable_i2c_instead_of_can = False (bool)
- enable_ascii_protocol_on_usb = True (bool)
- dc_bus_undervoltage_trip_level = 8.0 (float)
- dc_bus_overvoltage_trip_level = 25.68000030517578 (float)
- enable_dc_bus_overvoltage_ramp = False (bool)
- dc_bus_overvoltage_ramp_start = 25.68000030517578 (float)
- dc_bus_overvoltage_ramp_end = 25.68000030517578 (float)
- dc_max_negative_current = -9.999999974752427e-07 (float)
- dc_max_positive_current = inf (float)
- gpio1_pwm_mapping: …
- gpio2_pwm_mapping: …
- gpio3_pwm_mapping: …
- gpio4_pwm_mapping: …
- gpio3_analog_mapping: …
- gpio4_analog_mapping: …
- axis0:
- error = 0x0000 (int)
- step_dir_active = False (bool)
- current_state = 0 (int)
- requested_state = 2 (int)
- loop_counter = 0 (int)
- lockin_state = 0 (int)
- is_homed = False (bool)
- config: …
- motor: …
- controller: …
- encoder: …
- sensorless_estimator: …
- trap_traj: …
- min_endstop: …
- max_endstop: …
- watchdog_feed()
- clear_errors()
- axis1:
- config: …
- motor: …
- controller: …
- encoder: …
- trap_traj: …
- min_endstop: …
- max_endstop: …
- watchdog_feed()
- clear_errors()
- can:
- config: …
- can_protocol = 0 (int)
- set_baud_rate(baudRate: int)
- test_property = 0 (int)
- test_function(delta: int)
- get_oscilloscope_val(index: int)
- get_adc_voltage(gpio: int)
- save_configuration()
- erase_configuration()
- reboot()
- enter_dfu_mode()`
