The pole pairs are dependent on the motor. You can try finding them with the instructions here
Hall motors can go down to zero speed, but as speed decreases, velocity control fidelity is significantly reduced due to the low resolution of the hall sensors.
Other parameters you should look at are just desired continuous torque and speed typically.
