I am trying to compile https://github.com/Wetmelon/ODrive/tree/Endstops . Make clean works and make flash doesn’t. However, I can upload a new firmware by using openocd -f… and the Odrive works perfect. Can anyone please, tell me what I need to different to get to build a new firmware and upload it?
Thanks for your input. I downloaded the latest tup file for windows and I don’t see an exe installation file for it. How do I install it? should I place tup files within the Firmware?.
I used the command on git bash==>git clone git://github.com/gittup/tup.git to retrieve TUP. Also, I updated the windows path with C:\Users\Humberto\Downloads\ODrive-master\Firmware\tup
I believe is there. Do you have any idea how to install tup? I am using windows 7 64-bit. I downloaded the tup windows version and it doesn’t have installation file.
Simple unzip and copy it in a folder of your choice. But you have to add it to the Windows PATH.
I have unzip everything into the odrive\Firmware folder.
