Hey guys,
First time poster here, ive used an odrive with a hoverboard wheel for sim racing.
Ive started to work on a ffb brake pedal similar to what simucube has.
I have a 60mm nema 24 servo motor on the way.
The idea is that i want to create a torque curve, a seperate controller would deal with the logic of position vs load cell that part imo is easy imo.
The issue i have is i cant use torque mode to control the pedal as the motor has to backdrive the ballscrew to control the load via feed back from the load cell.
Should i use velocity control for this instance, does that make sense? Or even angle control?
I dont have the motor yet so i cant even test anything.
Thanks guys
