Does anyone have a part number for the CUI AMT102 encoder cable connector, the end that plugs into the odrive ?
you can search for a 2.54 wire to board connector. Or use a standard 2.54mm Female SIL Socket Row Strip PCB Connector and solder the wires.
Greetings / Zennix
hi,
Greetings Stijn
Yes I can hack one together but I can’t see one like the one on the cable in the shop ?
These don’t appear to have a pin coming out of the bottom ?
you need to crimp the wires into the pint and then push them into the plastic block
It’s a female pin header with a male header pushed in. I thought it was a single component. I didn’t think I’d ever seen one before.
