Current rating configuration for motor controller and motor
Hi
I wanted to confirm if the current rating on the odrive should be set to 2 x (current drawn by motor )?
The supplier of the motor mentioned that if I wanted the motor to draw 8A for the required torque then I had to set the motor controller current limit at 16A, does that make sense?
Hi! That’s maybe an okay rule of thumb, but I think there’s definitely better methods. It all really depends on the duty cycle of your application – if your motor will continuously be outputting maximum power/torque, you want your current limit to be the maximum current of the motor before it incurs thermal damage. However, if your application is characterized by brief transients between periods of lower load, you can set the maximum current to 2-3x the motor continuous current, and just make sure it doesn’t get too hot. The absolute best solution is to use a motor with a thermistor in it, and connect that to the ODrive – that way, the ODrive can monitor the temperature of the motor, and reduce the current if it gets too hot.
The motor will be pulling and releasing a loaded spring, so will mostly be under load. The rpm is low.
High torque, position control and smooth transition are the main concerning parameters.
What would the recommended configuration settings be for the above mentioned parameters?
Also could you please suggest the thermistor that could be connected to the motor to measure temperature on the odrive?
Thanks
Yes, setting the current limit to double the motor’s draw makes sense.
What motor are you using?
Thanks! Very cool!
It doesn’t seem like that motor has a thermistor, and 8A already seems very high for that size and resistance of motor, so I’d probably keep it to 8A just to be safe. You would have to take the motor shell off and add a thermistor inside it, which can be tricky and takes a lot of care.
Other than that, sounds like you would want position control in trapezoidal trajectory move – that provides for smooth point-to-point movements.
Do you mean 8A at odrive ( that would be 4A for motor ) or 16A at odrive ( 8A for motor)?
Thanks :blush:
The ODrive and motor will both see the same current. When I’m looking at this motor’s datasheet, I’m seeing a very small but high resistance motor, that’s going to generate a lot of heat at 8A. The datasheet is also specifying 8A as the absolute maximum current, and there’s also no thermistor in the motor to monitor the temperature. So I’d start with a current limit of 8A, but monitor the ODrive’s output current and ensure that it doesn’t go above around 4-5A continuous during normal operation. If so, you may need to decrease your current limit or get a stronger motor.
Thanks, will keep you posted as things progress .
Thanks!! Excited to hear more.
Hi
Do you recommend using the GUI or the odrivetool for setting the odrive PRO?
Also would I be able to log the position of motor shaft via the SPI without actuating the motor through CAN?
Thanks again :slightly_smiling_face:
Both are fine! They’re equivalent in terms of functionality. The GUI makes setup and tuning/basic control easier, so that’s usually what we recommend for getting started, especially if you’re new to using ODrives.
The ODrive’s SPI connection is only for connecting to encoders – but you can query the encoder angle through USB or UART via the axis0.pos_estimate property or CAN via the Get_Encoder_Estimates message.
I have an issue of pole pair mismatch.
But for some reason I was able to calibrate it via the odrivetool. When I perform position estimate (using Spi encoder),I get the position values but when I perform input pos to move the motor, the motor does not move. Trying to perform filtered position control .
Should the choice of motor be gimbal or High current?
Using this motor. Could you please suggest the proper motor configuration values for GUI?
Really appreciate the support.
