we are developing an electric gokart, and are looking into your project as a possible motor controller/drivetrain.
Is the D6374 motor from your shop a inrunner or a outrunner? (if possible we want to connect the housing to a heatsink if possible to get even more juice from the motor ).
Alternatively: does anyone know another motor that works well for a gokart (and is well suited for odrive)?
Itās an outrunner, as is any other ones in the shop. Anything on the low side of the KV range is going to be an outrunner. Your options are⦠push air through the motor and thereby across the stator, go up in motor capacity but run it at fractional amperage to reduce heat, go with an inrunner and gear it down, or⦠what I would do, use two motors since youāve got two channels anyway.
Pretty well any BLDC is āwell suitedā for ODrive aside from really high KV motors unless thatās just your thing. I would look at the Turnigy RotoMax series and the CA80 - the latter of which is excellent bang:buck at $170 for a 7KW motor. Keep in mind thatās 140A at 50v which is, Iām pretty certain, just beyond the ODriveās max amperage (unless youāre flying it through the air, though, youād probably run into heat issues on a kart at ODriveās max amperage anyway). Also keep in mind there are some losses, so while you may have 48v going into the board, youāll get something like 80% of that to the motor - so factor that in accordingly for your max RPM calcs.
Edit: If you do try the CA80, youāll want to push the motor shaft out the other end so that your load/pulley is at a more desirable location mechanically speaking.
The D6374 is indeed an outrunner. They do really well with a duct and a blower to push air through the stator for cooling. See this thread for example:
I would suggest a radial blower fan, they are very good at pushing air through small ducts, such as the gaps in the stator. This one I found was very good value.
You talk about turnigy ca80 , did someone have tested it?
I want to use it as spindle motor
Im esitate between ca80 or the D6374 from odrive
Wich one i will get more torque and speed with the limitation of the odrive,.
I try to find this answer but ,if i understand ca80 shoulb be better but no clear answer anywhere
My recommendation/mention of the CA80 was motivated merely by its advertised power and price. Iām not aware of anyone that has paired it with an ODrive yet. Speed will be dictated by gearing and KV rating - about equal for the two. Comparing just the power rating, you will get significantly more torque out of the CA80.
