I’m testing an 8318 motor connected directly to a pretty big flywheel (moment of inertia = roughly 0.006 kg/m^2). I don’t know if the inertia is relevant, just mentioning that in case it is. I’m using a power supply that can only supply 28.5V max and a 56V Odrive. The encoder is an AS5047P with AB interface hooked up (I don’t need index). Motor and encoder calibration work fine without any issues. After running <axis>.controller.input_pos = 1, the motor accelerates and then coasts. I get the following errors:
system: Error(s):
ODRIVE_ERROR_DC_BUS_UNDER_VOLTAGE
axis: no error
motor: Error(s):
MOTOR_ERROR_SYSTEM_LEVEL
axis1
axis: no error
motor: Error(s):
MOTOR_ERROR_UNKNOWN_TORQUE
controller: Error(s):
CONTROLLER_ERROR_SPINOUT_DETECTED
I’ve already tried increasing current_control_bandwidth to 2000 to no avail. Any idea what’s going on here?
