I am trying to calibrate the motor and getting the Axis: DC_BUS_UNDER_VOLTAGE error. I checked the voltage plotter and it does not show it dipping below 23 V and the UNDER_VOLTAGE_LIMIT is set at 8 V. Does anyone have any ideas?
–Thanks,
Jeff
–Thanks,
Jeff
You need a more powerful power supply, probably. What are you using to power the board?
I would also try shortening / twisting the wires to the power supply, and using ferrite rings on the motor outputs. Noise can cause this issue for me.
I had to bump up the calibration current, especially if trying to calibrate with a load.
Did this get any resolution? We are also having issues with DC_BUS_UNDERVOLTAGE errors (during operation, not calibration) and wondering if there were lessons learned here.
