I am trying to using odrivetool to control the BLDC. Unfortunally stop at the first step. The Terminal from Windows said Downloading json data from Odrive, however, it almost took me 3 hours. Nothing happened and changed.
Hi, which ODrive are you using? Where’d you get it?
You’re using an extremely old version of ODrivetool, can you show how you installed it?
Hi solomondg, we met at other topic. The same device, I got it from a self-making developer. It’s cheaper.
I tried to reload the driver and it worked. However, It will stuck at downloading json data for about 1 min. I think the problem is from the device.
Yeah, that makes sense.
