I’m using an ODrive 3.6, with odrivetool 0.5.4.
Despite having followed the Getting Started guide in each step, including saving configuration, each time the ODrive reboots I have to re-run the full calibration.
In [23]: odrv0.axis1.encoder.is_ready
Out[23]: False
In [24]: odrv0.axis1.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [25]: odrv0.axis1.encoder.is_ready
Out[25]: True
I understand this shouldn’t be the case with this firmware version.
If I don’t, and I attempt to enter closed loop control, the ODrive simply does not respond, and the following error message is found:
In [26]: odrv0.reboot()
Oh no odrv0 disappeared
Reconnected to ODrive 364D38633030 as odrv0
In [27]: odrv0.axis1.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [28]: dump_errors(odrv0)
system: no error
  axis: no error
  motor: no error
axis1
  axis: Error(s):
    AXIS_ERROR_INVALID_STATE
  motor: no error
What can the problem be?
Thank you.
