Hii everybody. There’s somebody that can show me how to connect asm 5047 encoder?
Connect MISO-MISO, MOSI-MOSI, SCK-SCK.
Connect CS to any of the numbered GPIO pins, and then remember to set encoder.config.abs_spi_gpio_pin to the number of the pin
obviously you should set encoder.config.mode=ENCODER_MODE_ABS_SPI_AMS
it’s also useful to set encoder.config.pre_calibrated=True and motor.config.pre_calibrated=True to take advantage of having an absolute encoder, so you don’t have to calibrate on boot.
That’s it.
thank you so much. I’ll tried immediately
Send rotation instruction buqizy
odrv0.axis0.controller.pos_setpoint = 1000
odrv0.axis0.controller.pos_setpoint = 0
Summary
Reconnected to ODrive 207035A1524B as odrv0
In [6]: odrv0.axis0.controller.pos_setpoint = 1000
Exception Traceback (most recent call last)
C:\ProgramData\Anaconda3\lib\site-packages\fibre\shell.py in
----> 1 odrv0.axis0.controller.pos_setpoint = 1000
C:\ProgramData\Anaconda3\lib\site-packages\fibre\remote_object.py in setattr
(self, name, value)
252 attr.set_value(value)
253 else:
–> 254 raise Exception(“Cannot write to property {}”.format(nam
e))
255 elif not object.getattribute(self, “sealed”) or name in
object.getattribute(self, “dict”):
256 object.getattribute(self, “dict”)[name] = value
Exception: Cannot write to property pos_setpoint
In [7]:
In Wetmelon’s RazorsEdge, you must use odrv0.axis0.controller.input_pos instead of odrv0.axis0.controller.pos_setpoint
My setup for the AS5047P is:
odrv0.axis0.encoder.config.abs_spi_cs_gpio_pin = 4
odrv0.axis0.encoder.config.mode = 257
odrv0.axis0.encoder.config.cpr = 2**14
Hi towen. why i’m not able to set encoder.config.mode=ENCODER_MODE_ABS_SPI_AMS
there’s not the option
I find …config.mode=ENCODER_MODE_INCREMENTAL or
…config.mode=ENCODER_MODE_HALL
thank you
Nicola- You need to be using the RazorsEdge branch of the firmware for this.
You need to clone the Git repo from https://github.com/Wetmelon/ODrive and then use ‘tup’ to build the firmware. If you’re on Linux e.g. Debian or Ubuntu or even a Raspberry Pi running Raspbian, this is trivial - on Windows it’s a bit tricky.
sudo apt install git tup gcc-arm-none-eabi build-essential
git clone https://github.com/Wetmelon/ODrive.git
cd ODrive/Firmware
cp tup.config.default tup.config
nano tup.config # you need to edit this file to put in your board type and version
tup
cd ..
tools/odrivetool dfu Firmware/build/ODriveFirmware.hex # to flash the firmware that you just built
