I had a weird issue which also result in this error code. However the reason mine was doing it was because I mounted the encoder on a shaft that was being driven by the motor and to fix the problem I had to get a longer motor shaft and mount the encoder directly to the motor shaft. Which was weird because I had the exact same setup on another motor driving a different axis (where the encoder was mounted on a shaft being driven by the motor) and it worked fine. All timing pulleys were tensioned properly as well. But it all works now in the new configuration so all is good!
Hey, this happened to me, and after examining my wiring, I discovered that some of them were not properly wired.
This fixed my issue as well. My Encoder was not aligned properly and whenever I entered closed loop control mode on that motor it would instantly skyrocket the Iq setpoint to my current limit and then throw an error. I have the output shown below where the first shows it working properly and the second code block shows it instantly skyrocketing.
Changed motor state for axis 0 to: 8
Iq Setpoint: -10.00, Iq Measured: -10.59
Iq Setpoint: -1.03, Iq Measured: -0.86
Iq Setpoint: 1.07, Iq Measured: 0.95
Iq Setpoint: 0.62, Iq Measured: 0.67
Iq Setpoint: 1.90, Iq Measured: 1.89
Iq Setpoint: 5.31, Iq Measured: 5.28
Iq Setpoint: 9.82, Iq Measured: 9.63
Iq Setpoint: 13.90, Iq Measured: 13.86
Iq Setpoint: 15.27, Iq Measured: 15.44
Iq Setpoint: 1.46, Iq Measured: 1.60
Iq Setpoint: 0.10, Iq Measured: 0.15
Iq Setpoint: -0.25, Iq Measured: -0.07
Iq Setpoint: -0.90, Iq Measured: -0.80
Iq Setpoint: 0.04, Iq Measured: -0.08
Iq Setpoint: -0.45, Iq Measured: -0.55
Changed motor state for axis 1 to: 8
Iq Setpoint: 0.00, Iq Measured: 0.03
Iq Setpoint: 0.00, Iq Measured: -0.02
Iq Setpoint: 0.00, Iq Measured: -0.03
Iq Setpoint: 0.00, Iq Measured: -0.01
Iq Setpoint: -13.84, Iq Measured: -12.06
Iq Setpoint: -20.00, Iq Measured: -19.14
I know it is solved, but wanted to add this for anybody else who encounters a similar issue. Thanks for the help!
i tried to do that but setting it to True can only be done when the encoder has been calibrated. But when the calibration can not be done because of the weird error: EncoderError.CPR_POLEPAIRS_MISMATCH.
When i check the encoder location it is read perfectly fine!
Help me configure the damn odrive
What encoder are you using, and what motor are you using? Are you calibrating under any load, or is the motor completely free spinning? Can you send a picture of how the encoder is mounted to the motor?
I use 400 pulse encoder (optical D3806-400BM). CPR number = 4*PPM = 1600.
The motor I use is 6010 DJI aircraft, it has 9 pairs of poles and speed coefficient is 130KV => torque coefficient Kt = 0.0735.
Below are the error image, configuration image, component image I used. Thank you for your attention, hope you can help me!!
Yes I would like to add some pictures of the motor and encoder configuration
Looks generally correct! Can you post a video of encoder calibration?
Having the same issue (
i’m on A2212, 7 poles, AMT10E3 encoder, odesc 4.2, odrive 0.6.5
motor calibration goes well, but encoder do not.
CPR is 8196, set to 0000 on encoder itself.
here is my encoder.config:
In [294]: dev0.axis0.encoder.config
Out[294]:
abs_spi_cs_gpio_pin: 1 (uint16)
bandwidth: 1000.0 (float)
calib_scan_distance: 20.0 (float)
cpr: 8192 (int32)
direction: 1 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: False (bool)
index_offset: 0.0 (float)
mode: 0 (uint16)
phase_offset: 0 (int32)
phase_offset_float: 0.0 (float)
pre_calibrated: False (bool)
use_index: True (bool)
use_index_offset: True (bool)
motor.config:
In [295]: dev0.axis0.motor.config
Out[295]:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
calibration_current: 5.0 (float)
current_control_bandwidth: 1000.0 (float)
current_lim: 20.0 (float)
current_lim_margin: 20.0 (float)
motor_type: 0 (uint8)
phase_inductance: 2.522823479012004e-06 (float)
phase_resistance: 0.05794057995080948 (float)
pole_pairs: 7 (int32)
requested_current_range: 60.0 (float)
resistance_calib_max_voltage: 1.0 (float)
torque_constant: 0.03999999910593033 (float)
torque_lim: inf (float)
once it finishes the motor phase calibration it sturts to rotate, but i see it jumps in the middle, may be this is the problem, skips some steps?!
took this motor only for the test of odesc, but cannot get it working well both sensorless and with an encoder. trying for couple days already ( any suggestions?!
Make sure you’re calibrating with zero load, and increase axis0.config.calibration_lockin.current to the max continuous current of the motor.
