When I calibrate the encoder, I report an error
Only use one motor. what can I do? thanks.
When the encoder is calibrated, the motor is twisted, the angle is very small, and it will not move
I found that the resistance and inductance of the same motor calibrated on different odrive boards are more than 30 times different. I don’t know if there is any problem here
Yeah, that’s not good. You might have to check for a short or something on one of the boards?
