Encoder Index Found always gets updated
I am trying to use z pin of the encoders for that I am requesting state = AXIS_STATE_ENCODER_INDEX_SEARCH after the calibration of motors. But nothing happened. I am getting no error bits. Also , one problem I have noticed that the variable index_found becomes true as soon as I started O drive even the z pin is low.
These are the config settings I have used
config:
  counts_per_step = 2.0 (float)
  step_gpio_pin = 7 (int)
  dir_gpio_pin = 8 (int)
  ramp_up_time = 0.4000000059604645 (float)
  ramp_up_distance = 12.566370964050293 (float)
  spin_up_current = 10.0 (float)
  spin_up_acceleration = 400.0 (float)
  spin_up_target_vel = 400.0 (float)
encoder:
  error = 0x0000 (int)
  is_ready = False (bool)
  index_found = True (bool)
  interpolation = 0.5 (float)
  phase = -0.2883787155151367 (float)
  pos_estimate = 0.0 (float)
  pos_cpr = 0.0 (float)
  hall_state = 6 (int)
  vel_estimate = 0.0 (float)
The state requested is
odrv0.axis1.requested_state= AXIS_STATE_ENCODER_INDEX_SEARCH
Problem : Nothing happened after this command .
Hope for a quick reply @madcowswe sir.
What encoder are you using? What cable are you using?
This is likely caused by electrical noise on the index line.
Thanks for the reply @madcowswe , I am using Yumo E6B2-CWZ3E 1096 ppr encoders with a properly made 5 pin relimate connector. I have checked the connections atleast 5 times and my z pin is also working with other mcu but still problem persists with o-drive.
Do you have a shield on the cable connected to ODrive GND? Can you check with an oscilloscope with a trigger level set to around 1.5V?
Hi, actually I have resolved the problem . When checked with oscilloscope , I found that the index pin is in high state when no index is found and becomes low on finding index. And may be odrive index works on level triggering. I have resolved the problem by using a not gate with the index pin. Thanks @madcowswe for the help . Can I find any doc related to the firmware or how the code works in odrive. Thanks.
