I am getting Pipe Error every few seconds that I use the controller for?
Anyone have any idea how I can debug this? Is it a hardware issue or a software issue?
File “/home/ubuntu/FYDP/foosfighter/odrive/core.py”, line 44, in fget
buffer = self._channel.remote_endpoint_operation(self._id, None, True, size)
File “/home/ubuntu/FYDP/foosfighter/odrive/protocol.py”, line 226, in remote_endpoint_operation
self._output.process_packet(packet)
File “/home/ubuntu/FYDP/foosfighter/odrive/usbbulk_transport.py”, line 72, in process_packet
ret = self.epw.write(usbBuffer, 0)
File “/usr/local/lib/python3.5/dist-packages/usb/core.py”, line 387, in write
return self.device.write(self, data, timeout)
File “/usr/local/lib/python3.5/dist-packages/usb/core.py”, line 948, in write
self.__get_timeout(timeout)
File “/usr/local/lib/python3.5/dist-packages/usb/backend/libusb1.py”, line 824, in bulk_write
timeout)
File “/usr/local/lib/python3.5/dist-packages/usb/backend/libusb1.py”, line 920, in __write
_check(retval)
File “/usr/local/lib/python3.5/dist-packages/usb/backend/libusb1.py”, line 595, in _check
raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 32] Pipe error
