I can run odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE fine with no errors
When I run odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL The motor spins super fast for half a second then stops… it gives me no resistance as it should, and then when I check the errors it gives me two axis: Error(s): motor: Error(s):
ERROR_CURRENT_UNSTABLE
ERROR_MOTOR_FAILED
I tried some of the fixes already suggested but nothing worked. What is wrong?
