Hello Folks, I am using USB cable of my PC to communicate to O-Drive using ASCII protocol.
I am writing code in c++, and using this attached library for communication over /dev/ttyACM0.
But sometime, there is some problem and it misses the recieved values.
For this I am using blocking_mode to end reception on receiving /n/r.
Do somebody have a working c++ code to communicate to O-Drive ove USB with ASCII protocol.
My code is as below:
#ifndef ODRIVE_CONTROL__HARDWARE_SERIAL_INTERFACE_H
#define ODRIVE_CONTROL__HARDWARE_SERIAL_INTERFACE_H#include <termios.h>
#include <fcntl.h>
#include
#include <string.h>
#include <errno.h>
#include <unistd.h>
#include <stdio.h>#define SERIAL_BUFFER_SIZE 128
class comm_serial
int fd;
char buffer[SERIAL_BUFFER_SIZE];int set_interface_attribs(int speed); void set_blocking(int should_block);public:
/* Send Command to Serial Port /
bool comm_write(std::string command)
int n = write(fd, command.c_str(), command.length());
if(n != command.length())
return false;
return true;
/ Read Response from Serial Port /
std::string comm_read(void)
std::string response;
memset(buffer, 0, SERIAL_BUFFER_SIZE);
int n = read(fd, buffer, SERIAL_BUFFER_SIZE);
if(n > 0)
response = buffer;
return response;
/ CONSTRUCTOR */
comm_serial(std::string portname, int speed)
fd = open(portname.c_str(), O_RDWR | O_NOCTTY | O_SYNC);
if(fd < 0)
printf(“error %d opening %s”, errno, portname.c_str());
set_interface_attribs(B115200); // set speed to 115,200 bps, 8n1 (no parity)
set_blocking(1); // set blocking
};int comm_serial::set_interface_attribs(int speed)
struct termios tty;
memset(&tty, 0, sizeof tty);
if(tcgetattr(fd, &tty) != 0)
printf(“error from tcgetattr: %d”, errno);
return -1;
cfsetospeed(&tty, speed);
cfsetispeed(&tty, speed);tty.c_cflag = (tty.c_cflag & ~CSIZE) | CS8; // 8-bit chars // disable IGNBRK for mismatched speed tests; otherwise receive break as \000 chars tty.c_iflag &= ~IGNBRK; // ignore break signal tty.c_lflag = 0; // no signaling chars, no echo, // no canonical processing tty.c_oflag = 0; // no remapping, no delays tty.c_cc[VMIN] = 0; // read doesn't block tty.c_cc[VTIME] = 5; // 0.5 seconds read timeout tty.c_iflag &= ~(IXON | IXOFF | IXANY); // shut off xon/xoff ctrl tty.c_cflag |= (CLOCAL | CREAD); // ignore modem controls, enable reading tty.c_cflag &= ~(PARENB | PARODD); // shut off parity tty.c_cflag |= 0; tty.c_cflag &= ~CSTOPB; tty.c_cflag &= ~CRTSCTS; if(tcsetattr(fd, TCSANOW, &tty) != 0) { printf("error %d from tcsetattr", errno); return -1; } return 0;}
void comm_serial::set_blocking(int should_block)
struct termios tty;
printf(“error %d from tggetattr”, errno);
return;
tty.c_cc[VMIN] = should_block ? 1 : 0;
printf(“error %d setting term attributes”, errno);
}#endif // ODRIVE_CONTROL__HARDWARE_SERIAL_INTERFACE_H
