Hi
I want to communication between esp32 and ODrive using CAN interface. However, I can’t control my motor for velocity control at ODrive .
Can someone help me ? Thanks a lot!
My config and code:
odrv0.axis0.config.can_node_id = 3
odrv0.axis1.config.can_node_id = 1
odrv0.can.set_baud_rate(500000)
#include <CAN.h>
void setup() {
Serial.begin(115200);
while (!Serial)
Serial.println("CAN Sender");
// start the CAN bus at 500 kbps
if (!CAN.begin(500E3)) {
Serial.println("Starting CAN failed!");
while (1)
// ID for ODrive
int canID = (0x003 << 5) + 0x00D;
// velocity set point
int setV = 20;
// CAN message
unsigned char stmp[6] = {setV, (setV >> 8), (setV >> 16), (setV >> 24), 0, 0};
void loop() {
CAN.beginPacket(canID);
CAN.write(stmp, 6);
CAN.endPacket();
delay(5000);
// try to parse packet
int packetSize = CAN.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received ");
if (CAN.packetExtended()) {
Serial.print("extended ");
if (CAN.packetRtr()) {
// Remote transmission request, packet contains no data
Serial.print("RTR ");
Serial.print("packet with id 0x");
Serial.print(CAN.packetId(), HEX);
Serial.print(" and requested length ");
Serial.println(CAN.packetDlc());
} else {
Serial.print(" and length ");
Serial.println(packetSize);
// only print packet data for non-RTR packets
while (CAN.available()) {
Serial.print((char)CAN.read());
Serial.println();
delay(5000);
Serial.println();
Serial monitor:
