Can anyone tell me what amount of noise you’d expect to see when plotting vel_estimate, when the motor itself is completely motionless?
EDIT: and with what encoder, encoder mode you’re using, obviously.
Really depends. With the AMT102s from the shop, 0 noise. With a magnetic SPI encoder… it can vary and it depends on encoder.config.bandwidth, but maybe +/- 0.1 turns/sec?
Thanks for your response. I was seeing +/-0.3 when bandwidth=1000, it came down to +/-0.01 when bandwidth=100.
Is there any downside to having bandwidth as low as possible? I see that pos_estimate takes a while to converge at really, really low bandwidths (bandwidth=1) but I can’t tell from the liveplotter at what point this becomes negligible (from the perspective of controller performance).
It creates an error between the actual angle and the sensed angle. This can cause issues with the motor control, but it’s going to be totally application dependent.
Okay, I will experiment. Thanks for the info.
