I tried to compile and flash the firmware on Windows with Visual Studio. When I try to build firmware I get the following error
_> Executing task in folder Firmware: make -j4 <_
_Het systeem kan het opgegeven pad niet vinden._
_Middlewares/Third_Party/FreeRTOS/Source/list.c:238:1: fatal error: opening dependency file .dep/list.o.d: No such file or directory_
_ }_
_ ^_
_compilation terminated._
_make: *** [build/list.o] Fout 1_
_make: *** Wachten op onvoltooide taken..._
_Middlewares/Third_Party/FreeRTOS/Source/event_groups.c:714:1: fatal error: opening dependency file .dep/event_groups.o.d: No such file or directory_
_ }_
_ ^_
_make: *** [build/event_groups.o] Fout 1_
_Middlewares/Third_Party/FreeRTOS/Source/queue.c:2351:2: fatal error: opening dependency file .dep/queue.o.d: No such file or directory_
_ } /*lint !e818 xQueue could not be pointer to const because it is a typedef. */_
_ ^_
_make: *** [build/queue.o] Fout 1_
_Middlewares/Third_Party/FreeRTOS/Source/tasks.c:4801:1: fatal error: opening dependency file .dep/tasks.o.d: No such file or directory_
_ }_
_ ^_
_make: *** [build/tasks.o] Fout 1_
_The terminal process terminated with exit code: 2_
Then I tried the .elf file (subject :looking for compiled firmware) and placed it in the build directory
After trying to flash I got in then openocd.log
_Info : Listening on port 6666 for tcl connections_
_Info : Listening on port 4444 for telnet connections_
_Info : Unable to match requested speed 2000 kHz, using 1800 kHz_
_Info : clock speed 1800 kHz_
_Error: libusb_open() failed with LIBUSB_ERROR_ACCESS_
_Error: open failed_
_in procedure 'init' _
_in procedure 'ocd_bouncer'_
Possibly the visual studio release is too new (2018-01-18)
I have also a raspberry pi. I was able to create an .elf file but uploading wouldn’t work. Somewhere I read that someone had the same kind of problems due to an old version of linux. I renewed the Linux version from jessie to stretch.
Trying to run make got the following error
In file included from MotorControl/commands.cpp:9:0:
MotorControl/commands.h:9:22: fatal error: functional: No such file or directory
Makefile:166: recipe for target 'build/commands.o' failed
make: *** [build/commands.o] Error 1
Just for the hack I commented out that line, and the I got
MotorControl/commands.h:10:18: fatal error: limits: No such file or directory
Probably there are more files missing
Is there a better way to go?
