I was able to grab a university laptop with Ubuntu installed and tried the process again.
I first tried flashing the firmware and was getting the following two errors. The first error occurs the first time I try the command, and every time I try the command after that before power cycling everything I get the second error.
wiu@Computer:~ cd ~/Desktop
wiu@Computer:~/Desktop sudo openocd -f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c init -c âreset haltâ -c âflash write_image erase ODriveFirmware_v3.6-56V.elfâ -c âreset runâ -c exit
[sudo] password for wiu:
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport âhla_swdâ. To override use 'transport select '.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v17 API v2 SWIM v4 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.255666
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
auto erase enabled
Info : device id = 0x10076413
Info : flash size = 1024kbytes
Error: jtag status contains invalid mode value - communication failure
Error: error waiting for target flash write algorithm
Error: error writing to flash at address 0x08000000 at offset 0x00000000
wiu@Computer:~/Desktop$ sudo openocd -f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c init -c âreset haltâ -c âflash write_image erase ODriveFirmware_v3.6-56V.elfâ -c âreset runâ -c exit
none separate
Info : Target voltage: 3.247714
auto erase enabled
Error: failed erasing sectors 0 to 5
I then tried the unlock command, which made some progress, but seems to be stuck in an infinate loop where the communication times out every 3-4 minutes. I sat there letting it run for about 15-20minutes with no luck.
wiu@Computer:~$ openocd -f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c init -c âreset haltâ -c âstm32f2x unlock 0â
none separate
Info : Target voltage: 3.249768
stm32f2x unlocked.
INFO: a reset or power cycle is required for the new settings to take effect.
Polling target stm32f4x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
I could be wrong as I am new to this openocd software, but I think we can confirm the TX2 was the issue we were encountering previously, but now we are still having issues with flashing the firmware. I do not want to rule out saving this board, but with the end of the semester coming up shortly, do you think it would be in our best interest to purchase a new board that already has the 5.1 firmware due to time constraints?
Again, thanks for all of the help.
Edit: I do want to note that I did try the firmware update again after trying the unlock command multiple times with the same result.
