I keep getting this motor error after going through the getting started configuration for my motor on Odrive 3.6.
After configuration I instruct the Odrive to move the motor one or two turns in one direction than a turn or two back to check functionality. There is no significant load on the motor.
I’m thinking there is either something wrong with my setup or something else I should be configuring?
system: no error
axis: no error
motor: Error(s):
MotorError.UNKNOWN_TORQUE
MotorError.UNKNOWN_VOLTAGE_COMMAND
DRV fault: none
controller: Error(s):
ControllerError.OVERSPEED
The configuration for my motor is as follows:
odrv0.axis0.motor.config.current_lim = 40 <== Using Meanwell SE-450-24 Power Supply
odrv0.axis0.motor.config.calibration_current = 20
odrv0.axis0.controller.config.vel_limit = 2
odrv0.config.enable_brake_resistor = 1
odrv0.config.dc_max_negative_current = -0.01
odrv0.axis0.motor.config.pole_pairs = 7 <== Motor = D6374
odrv0.axis0.motor.config.torque_constant = 0.0551
odrv0.axis0.motor.config.motor_type = 0
odrv0.axis0.encoder.config.cpr = 20480 <== ENCODER = CUI AMT10E2-V
odrv0.save_configuration()
odrv0.axis0.controller.input_pos = 0.02
odrv0.axis0.controller.input_pos = 0.5
odrv0.axis0.controller.input_pos = -2
odrv0.axis0.controller.input_pos = -1 <== NO RESPONSE
