Hello community,
this is the first try to use odrive. Following the docs the next step was to upgrade the fw with `odrivetool dfu
The erasing was succesful, but the writing not. This is the error what I get.
Edu-MacBook-Pro-226:~ eduard$ odrivetool dfu
ODrive control utility v0.5.2.post0
Waiting for ODrive…
Found ODrive 206439A04D4D (v3.6-24V) with firmware v0.4.11-dev
Checking online for newest firmware… found v0.5.2
Downloading firmware v0.5.2…
Putting device 206439A04D4D into DFU mode…
Erasing… done
Flashing… (sector 0/7)
File “/Library/Frameworks/Python.framework/Versions/3.6/bin/odrivetool”, line 148, in
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/odrive/dfu.py”, line 471, in launch_dfu
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/odrive/dfu.py”, line 397, in update_device
dfudev.write_sector(sector, data)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/odrive/dfuse/DfuDevice.py”, line 202, in write_sector
raise RuntimeError(“An error occured. Device Status: {!r}”.format(status))
I have a brick now?
Thanks.
