I’m finally giving this ODrive I bought a while back a try. It’s a version 3.5. I’m trying to run two “hoverboard” motors. These are my thoughts going through the process.
- Hoverboard getting started requires the main getting started to be finished first. Maybe add some text to that effect and a link? Google brought me to the hoverboard getting started page.
- ODrive needs
libjpeg-devandlibz-devinstalled to install on Raspberry Pi OS Lite for the “pillow” Python dependency to install correctly - ODrive setup does not add proper udev rules (as it suggests it does in the Getting Started guide)
odrivetoolhas a bunch of distracting errors on startup:
pi@raspberrydrive:~ $ odrivetool
ODrive control utility v0.4.12
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('import sys')
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('superexcepthook = sys.excepthook')
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('def newexcepthook(ex_class,ex,trace):\n'
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('sys.excepthook=newexcepthook')
Please connect your ODrive.
odrivetool --help suggests running sudo odrivetool udev-setup which seems to do the udev setup. Maybe this should be added to the getting started?
Now I can run odrivetool as the pi user and it detects my ODrive!
Connected to ODrive xxxxxxxx as odrv0
In [1]: 1
Out[1]: 1
In [2]: odrv0.vbus_voltage
Out[2]: 12.221117973327637
In [3]:
Time for some fun!
