I get new ODrive and I am trying to configure it to run with my hoverboard motor. But I get this errors when I try to configure it.
Running “odrv0.axis0.motor.config.torque_constant” produce this error “AttributeError: ‘RemoteObject’ object has no attribute ‘torque_constant’”.
Running “odrv0.axis0.controller.input_vel = 2” produce this error “AttributeError: Attribute input_vel not found”
I believe it is a problem with Python and pip but i can not figure it out.
Any ideas, suggestion, solutions.
SOLVED by updating odrive with “odrivetool dfu”
when I type in “odrivetool dfu” I get invalid syntax how do I update odrive
pip3 install odrive ?
pip install --upgrade odrive
Hi I’m facing the same issue, I have upgrade odrive with dfu command but still can’t get it to work. any other ideas?
