would setting the torque limit clamp the commanded current? if so how do i determine the torque limit? I am thinking of the following options and would appreciate the help.
option 1: Based on the motor max torque I would set the torque_limit to 8 N.m, which really means that the current limit is 1908/8.27 = 183.8A (T=8.27Current / KV). Which contradicts with the max current of 85 Ams given by the manufacturer.
option 2: Based on the motor max current I would the torque limit to 3.7N.m, which is based on T=8.27*current/KV. This contradicts with the max torque of 8N.m given by the manufacturer
I am using flipsky 6374190KV BLDC motor (link below), the specs are the following:
- Max Current: 85 Amps
- Max Volts: 12S
- Max Torque: 8Nm
- Motor Resistance: 0.05Ohm
- The number of pole: 14
What am i missing in here?
