New here. Sorry, this should be in support.
For 24V motor with says, 1024 per revolution sensor
A. How many magnetic poles are suitable
B. Is it correct that 1024 step sensors can run smoothly at near zero speed of 0.5 RPM or even slower?
C. What other parameter I need to match a motor.
- As state in some motor specification,
is 1024 step sensor, refer to quadratic, 2 lines outputing square wave, 90 degrees apart as in below?
Thank you
