Hi, as the question states; can someone please guide me to the quickest way to avoid startup calibration? I’m using the following temporary solution but the motor still does an offset calculation at startup.
odrv0.axis0.config.startup_encoder_offset_calibration = True
odrv0.save_configuration()
Thank you in advance to you wonderful people
