i want to know how to let odrive run a motor without run_calibration process.
i can input p_gain i_gain, phase_resistance and phase_inductance by my self.
but i don’t have current measured.
i’ve found that the odrive control loop run open loop control before current controller.
so that , if i don;t have current measured. still can’t run openloop mode .
Hi, If you’re confident in your values for phase_resistance and phase_inductance you can bypass the motor calibration by setting:
{odrv}.axis0.config.motor.phase_resistance = {your phase_resistance value}
{odrv}.axis0.config.motor.phase_resistance_valid = True
{odrv}.axis0.config.motor.phase_inductance = {your phase_inductance value}
{odrv}.axis0.config.motor.phase_inductance_valid = True
You cannot bypass the encoder calibration, unless you are running sensorless.
Out of curiosity, why do you want to run open loop?
