I can't get information from CAN bus, only heartbeat packets
I can’t get information from CAN bus, only heartbeat packets
The restart command I send can be executed correctly, and the command to get the information has not received a reply, but ODrive has been sending heartbeat packets, and nothing but heartbeat packets can be received.
Is it wrong with ODrive settings?
Make sure you set the RTR bit (frame.rtr = True) when sending request packets
