Hey all,
I have an S1 and am using the built in encoder. When in torque control mode I tend to get an inconsistent torque output as I “pull” on the motor against its direction of motion the torque feels like it climbs, then drops suddenly, and then repeats over and over. What is weird is that when I use the motors Hall effect sensor this issue goes away but I get muttering due to the low resolution.
I e attempted calibrations, changed setups. But the problem persists. It also seems to be worse at higher torque values although maybe just more perceive-able.
