Just getting started here… trying to figure out a way to configure the O-Drive to run based off of simple IO signals. Anyone know if this is possible? Ideally I one GPIO pin would turn the motor on at a predetermined RPM, and another IO would return confirmation once the RPM is reached. Any idea if it can do this?
It has been a while, and I would like to check in on this. I am pretty new to programming micro-controllers and would really like to learn more. What you are describing sounds like a good way to get my foot in the door.
