I have been trying to connect to the ODrive using Putty or Tera Term by changing the ODrive Native Interface in Zadig to usbser like in the documentation.
I get a failed to connect notification each time I try. Not sure what I am doing wrong.
I have been able to connect to the ODrive and do everything using Anaconda, so I know that part is fine.
Please let me know what information I might need to provide to move forward.
Zennix, I changed the port to COM2 and tried to reconnect. It still failed. I went ahead and put together a quick serial connection program using C++ and Qt to try to get a little more information on to why the connection failed.
I am getting an error string that says “The system cannot find the file specified”. From Qt documentation, it says that this error shows when trying to connect to a non existing device.
This is what shows in my device manager under com ports. So my computer recognizes the ODrive after I change the driver to usbser, but I cannot seem to connect to it.
I’m fairly certain the ascii doc is out of date. Interface 2 is for the native protocol. Look through your “Communications Port” items for one with a vendor ID of 1209 (or just pay attention to which one appears/disappears when dis/connecting) and try that one.
