If I create a plot using start_liveplotter, then close it, I get the following exception:
In [80]: Exception in thread Thread-10:
File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
self.run()
File "/usr/lib/python3.5/threading.py", line 862, in run
self._target(*self._args, **self._kwargs)
File "/home/alex/.local/lib/python3.5/site-packages/odrive/utils.py", line 74, in plot_data
fig.canvas.start_event_loop(1/plot_rate)
File "/home/alex/.local/lib/python3.5/site-packages/matplotlib/backend_bases.py", line 2251, in start_event_loop
self.flush_events()
File "/home/alex/.local/lib/python3.5/site-packages/matplotlib/backends/_backend_tk.py", line 491, in flush_events
self._master.update()
File "/usr/lib/python3.5/tkinter/__init__.py", line 1028, in update
self.tk.call('update')
_tkinter.TclError: can't invoke "update" command: application has been destroyed
odrivetool still works, however if I try to start another plot, the whole thing crashes with the following error:
In [80]: start_liveplotter(lambda: [odrv0.axis0.encoder.vel_estimate])
Out[80]: <fibre.utils.Event at 0x7f7964edf470>
In [81]: Exception ignored in: <bound method Image.__del__ of <tkinter.PhotoImage object at 0x7f7968fa54a8>>
File "/usr/lib/python3.5/tkinter/__init__.py", line 3359, in __del__
self.tk.call('image', 'delete', self.name)
RuntimeError: main thread is not in main loop
Tcl_AsyncDelete: async handler deleted by the wrong thread
Aborted (core dumped)
This is on Ubuntu 16.04.
