Hi!
My team and I bought around 16 ODrives for a project. We are working with hoverboard motors in our robot (1 ODrive per robot) and communicating with Odrive through ASCII protocol. Our robots can carry different weights and we want them to maintain same speed at any weight (from 0kg extra weight to around 60-90kg extra weight). Now we are using velocity control with “v” ascii protocol command and we have also tried setting the velocity with vel_ramp_target and “w” ascii protocol command. The robot is moving fine in both cases when carrying 0kg but when we add weight it slows down. What are we doing wrong or what can we do to fix this?
Thank you in advance for your help and work.
Greetings!
